I'm guessing that time I had to put that new belt on at 5am on the side
of the road in the pitch black didn't help the situation. The belt is still on
there, but the alternator seems to have suffered for it as I believe I
overtightened the bolt. Now it wont get 100% tight and just keeps rotating
like an endless screw.
So far it's holding. Yesterday it chirped in first gear almost every time I started
off on the way to work and so I tightened it when I got home and noticed that
the bolt just keeps going. I drove it in today to test it and it only chirped once,
but I'm thinking the alternator is slowly moving back towards the engine and
causing the belt to slip slightly.
Has anyone ever drilled out their alternator hole and used a bolt with a lock washer
and nut on the back side with any success? That's pretty much my thought on the
matter rather than getting a new alternator. I don't feel like spending a bunch of
money on stuff right now if I can help it and this fix seems cheap, but I'm wondering
before I ruin the remaining threads on the alternator if I should do that or try and
tap it out with a bigger thread and use a larger diameter bolt instead. Anyone have
any ideas?
any ideas?
