Nice to know that an Aspire housing can be used (with an Aspire hose). Good on ya for figuring that out.
Since the hoses are pre-formed, I would be reluctant to use the Festy hose with an Aspire housing. But there are the accordion-style hoses that should work with no issues.
But the Aspire housing has no temp sensor in it. Still worth doing if you just had to have the car running. You could rig up a manual switch for the fan to turn it on as needed, while keeping an eye on the temp gauge.
I don't understand your comment in post #9 where you said you didn't need the housing's thermoswitch, because the ECU handles it. But the ECU needs the data from the switch or somewhere else to know what to do. Is this done differently on your carby cars over there? I wonder if this is true of US carby cars too.
