Originally posted by jroberson1981
90' Festiva head gasket job?
If they are rounded, the bit for it isn't going to fit either, have a pic of them?Contact me for information about Festiva Madness!
And yeah, unless you are also replacing the timing belt, you don't have to remove them anyway.Contact me for information about Festiva Madness!
Get a Haynes manual; save you a lot of time asking very basic questions. The timing belt does not need to come off the crankshaft, just the head. You are going to need the manual for all the torque specs anyway, so just go buy it. Also, on the top timing belt cover, there is a bolt that is hard to get to, in the rear down by the timing belt tensioner. If/when you get that one off, don't put it back in. Cut the upper cover above it, and around the WP pulley so it won't ever rub. The other three are easy to find.Originally posted by jroberson1981 View PostSo how do I take the head off then if I don't need to take the timing belt offLast edited by TominMO; 09-04-2015, 09:23 PM.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
Haynes manual does cover this, and you really should get one, as Tom says. Still. You can loosen the tensioner, pull it back, then tighten the bolt to hold it in place, then slip belt off cam sprocket. Later, you just make sure it is seated properly on the crank and reinstall.Contact me for information about Festiva Madness!
Thank you.. I do have the manual and just wanted to make sure that's what and how I really could do it.. thank you so much for your helpOriginally posted by scitzz View PostHaynes manual does cover this, and you really should get one, as Tom says. Still. You can loosen the tensioner, pull it back, then tighten the bolt to hold it in place, then slip belt off cam sprocket. Later, you just make sure it is seated properly on the crank and reinstall.
