Windshield washer lacks power
  • Windshield washer lacks power
    Well, I bought another Festiva and I've tried 2 washer tanks on it
    so far and none of them will spray more than a small stream on the
    windshield before giving up. Is it possible that both pumps are too
    weak? I tried testing them outside of the car and they shoot a decent
    stream of water, but once it's in the car it'll spray a bit and then quit.
    The line will stay full as long as you're holding down the sprayer, but
    when you let off the water drains back down. Is this a bad valve or
    something? Should I just get a universal pump off of RockAuto?
    1993 Festiva - White/Black - 5 speed
    I had trouble with a car I had. When I got it there was no lid on the washer tank. I removed it and cleaned it out. It needed it but it ended up needing the nozzle on the hood cleaned out as well.
    '89L 110k mi. BP/G swapped
    '90LX 68k mi. wrecked 12/14 RIP
    '90 F250 4X4 108K mi.
    '13 Kia Rio 5 LX 70k mi.
    '18 Kia Soul 40k mi. Daily
    '64 Studebaker Gran Turismo Hawk
    '66 International Harvester pickup
      I threw a lid on the washer tank and it's sealed well. The sprayer nozzle was from
      Fourgreen so it's brand new.
        Thread 49099
          Have you checked the tube from pump to nozzle ?
          You can get the replacement pumps at AutoZone cheap.
          Take the old one in with you.
          I also have the flat 3 noz Smart car sprayer.
          Thanks to brave for that idea.
          I love it.
          '93 Green L - ' Tiva
            Yeah, the tube was broken at first so I replaced it with one from another Festiva an it'll spray a small amount on the windshield and then it quits. No leaks, just won't get through. And unless the new nozzle from Fourgreen is plugged up I don't think that's the issue. Maybe I'll run up to Autozone and grab a new pump here soon
              Try a little puff of air pressure through from tube side and outside, high pressure will/might blow hose connections loose. I have had success with this before.
              "Wenona"-89L parts car
                I'll give that a go when I go over to my friend's house next. I dont have a compressor where I live
                  Try blowing into the tube. If you "give up" too it's probably the line.
