Bp idle rev and stall.
  • Bp idle rev and stall.
    I been working on my car trying to get it back running good to driver everyday. I only waiting for tires to come in. I usually crank it daily to let it warm up and make sure everything is running good. Yesterday it did great. Today I started it let it run for about 5 mins it done great. I decided to rev it a little not much just over 1200 rpms and when I take foot off gas it tries to die. If I hold foot on gas it will smooth out until I remove it again. It will cut off if I let it. I popped the hood and played with air intake hose some and started it back it ran fine until I rev it again any idea what it could be?
    Forgot to mention after it does this it hard to get to start back.
    1990 Red Festiva STOCK "pregnant roller skate"
    1989 Yellow Festiva BP swap "Freebird"
    2007 Ford F150 "black sunshine" full exhaust with x-pipe. K&N intake. Headman Headers.
    2001 Honda accord SOLD lots of goodies done suicide doors lowered 20 inch rims
    2005 Ford F250 6.0 Turbo Diesel "swamprat" 4 inch lift, 4 inch mbrp exhaust, egr delete, glowshift pillar gauges.
    1994 Ford F150 5.0 Completely stock.
    I just adjusted the idle up a bit and it did fine again. Seems to be ok. Still seeing of anything I need to check?
      Still acting up. Only when you rev it up though. After that it acts like it starving for something.
