Originally posted by Flyin4stroke
Distributor installation
I used grease; didn't help. That was one tight o-ring.Originally posted by Meepersly View PostI had this problem with my efi dizzy when converting carb to efi I took some motor oil and put it on the wings that go I to the cam and on the area the oring is and it slid in like nothing was was being a problem before.
Hope to crank it up tmw. Still have to finish putting it back together (not that much to do really), and have to go get exhaust connector pieces at McParts. I'll crank it up just to check stuff, then add coolant, and remove the exhaust pieces and take 'em in to my fave exhaust shop to weld some of them. In a couple of places I'll still use clamps for ease of removal.Originally posted by Flyin4stroke View PostDoes it run?
I think today I'll install the exhaust to see what I will need in terms of spacing, and pipe length.Last edited by TominMO; 09-16-2015, 08:43 AM.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
They are different? I would swear I am using a B3 dizzy in my second gen B6.Originally posted by TominMO View Post: sticking in a Festy EFI B3 disty. I think that will work electronically if I have to go that route; the only issue is that I can only use one bolt to hold the disty on, since the gen2 head has its lower bolt slot at a different angle than Festys and gen1 B6s. Not a biggie tho, I know some people only use one bolt anyway.
Yeesh, I need to document things! My memory is WORTHLESS!Contact me for information about Festiva Madness!
Just ran into a similar issue to some of you guys. I have the b3 disty in the B8 sohc, but it took FOREVER to install. However, when I went to retard the timing - it didn't have enough play. So, I took both 12mm bolts out and went back even further until the engine lost the continuous misfire. I have a timing light, but how do I get it to stay there with no way to mount it in place? Suggestions?
Make a tab that you can bolt one end to the head and the other end to the dizzy ear.Any difference that makes no difference is no difference.
Founds like it could be 180* out of time. On a b3 distributor you can install the rotor in 3 different directions. It can be easy to install 180* out the rotor will be somewhat close if you do it right but the actual shaft is what is 180* out not the rotor.Last edited by Meepersly; 10-13-2015, 09:08 AM.88 Ford Festiva LX "Miogi" B8-ME swapped.
93 Ford Festiva L "Haywire" Rat infested trashcan WIP
