Low power sometimes got power.
  • Low power sometimes got power.
    Replaced o2 sensor. Not the vaf. Throttle position sensor is good. At first it was slow after the efi swap then it got a little better. It felt like it wanted to screech the tires every time I started moving at an intersection. I loved it. While I was driving it around 65 mph it started loosing speed. I Pressed the accelerator to gain speed it did but it was a bit slow. Its intermittent sometimes but for the past few days it has stayed the same. Car runs fine starts every time. I did notice though when it is running faster the idle is a little higher. Is there a sensor somewhere that I haven't checked?
    88 Ford Festiva LX "Miogi" B8-ME swapped.
    93 Ford Festiva L "Haywire" Rat infested trashcan WIP
    Also I am only getting around 20mpg so it must be running rich for some reason
      Forget the above how does one delete a thread?
        What was it
          Timing belt decided to jump some teeth. Looks like I got a project tomorrow.
