Since Madness I have been driving the 93 5-speed Festiva (aka the 350 car). The PO had set the idle speed at 2100 rpm so I tried slowing it down some using the air mixture screw on the top of the throttle body but even closed all the way it was still idling @ 2000. I took a look at the "do not adjust/set at factory" (according to the shop manual) adjustment screw down below the base of the throttle cable cam on the throttle body. The 8 mm squirrel nut was loose so I know the PO had adjusted it. I adjusted it to slow the idle speed some but would like to get things back to factory specs.
How should this be adjusted?
Thanks.
Thanks.
