been told I can use efi engine in a carby car if................
  • been told I can use efi engine in a carby car if................
    I Just swap the intake, exhaust manifolds, and distributor. May have to swap the cam to use the fuel pump. Cover plate should be there. Just take it off.
    thanks to un-named member.
    Is that correct? - no other problems? other opinions are welcome.
    admit nothing - deny everything - make accusations
    If it is a Festy engine you won't have to swap the cam. They all have fuel pump lobes. Aspire engines don't.
      Yup. It is the exact same engine.
        Paul, I think the motor in question is an Aspire, due to another thread asking a similiar question. That should mean a cam swap also.
        Jerry
        Team Lightning
        Owner of Team Lightning
        93 L Lightning. BP
          Ahh, didn't know that, but the quote I used did say if it's Festiva engine. Any hole, yeah, the aspire engines didn't have a cam lobe for the fuel pump, and if I recall correctly, the rocker arms don't work properly either? Not sure about that though.
          Sent from somewhere outside the asylum via tapatalk
            I don't think the rollers on the Aspire cam will last when put on a standard Festiva cam. I'm sure I read on here they need changed also.
            Jerry
            Team Lightning
            93 L Lightning. BP
              Yeah, that is what I recall Jay saying he tried once. Using Aspire cam with rollers is OK on the EFI Festiva. No personal experience with it though.
                This is correct except that carbed engine have manually adjusted valves and the EFI had hydraulic lash adjusters.
                The Festiva Store
                  call me old school, but i like better the manually adjusted valves......
                    Yup, forgot about that, I ALWAYS forget about that.
                    Check that, I forget about LOTS of stuff. Worlds worst memory, I swear.
