No heat to top vents? 1993 Festiva
  • No heat to top vents? 1993 Festiva
    I have a 1993 Festiva GL. I have just replaced the thermostat in it. With success of getting heat in the floor vents and my defroster now blows heat. My top vent will still blow out cold air please help. Thank you in advance.
    That's just the way a Festiva is.
      ^yup! Kinda silly design "feature".
      - Form should follow function...
        I hear you have to go to Arizona to get your heater to blow hot air through the top vents.
        1989 Ford Mustang GT 5.slow
        1996 Ford F-150
          Festivas can sense differences in the earths gravitational pull and they give off more heat from those vents the closer you are to the equator. Also the vent is scared of the dark so it generally gives off more heat when the sun is up.
            You guys are crazy lol I'm really surprised nobody has came up with a solution to this after all these years
              My dad rerouted some of the floor ducting to his. It worked OK.. I just keep mine on defrost/ floor lol.
                On my drive home from work today i was thinking about that! Was it just as warm or did it mix with cold air too much to be worthwhile?
                  He had to put in a warmer thermostat.
                  Sent from my ALCATEL A845L using Tapatalk
                    I have just disconnected my heater core from the engine and given up.
                      Thanks I didn't know. This car is new to me
                          You could try putting a heater core where the a/c condenser would be, butbthen you have heat all the time.
                          88 Ford Festiva LX "Miogi" B8-ME swapped.
                          93 Ford Festiva L "Haywire" Rat infested trashcan WIP
                            He could do that and put a manual valve on it.
                              On my car, even when heat is coming out of the top and bottom vents, cold air(on cold days) comes out of the center vents. Something probably isn't sealing right. I get air coming out of the vents when nothing is on while driving down the road.
                              Rick
                              1993 Ford Festiva
                              1986 AMC Eagle Wagon 4.2L/4.0L head, AW4,NP242, Chrysler 8.25" rear. SOLD
                              1981 AMC Eagle Wagon-As Seen on TV Lost In Transmission
                              2000 Ford E350
