No heat to top vents? 1993 Festiva
  • #31
    Originally posted by TorqueEffect View Post
    same here. And I also get a trickle of cold air out the main vents while on floor and or defrost.
    Oh yeah, I get this too.
    Originally posted by william View Post
    Blinding door seal / cable misaligned
    Yup. I'm just living with it, at least for now. It heats adequately in the winter--considering I'm already wearing season-appropriate clothing. When I really want to drive warmly, I just jump in the Aspire, where the heating system works perfectly. Besides getting heat out of the dash vents, I wonder if the Aspire system was upgraded quality-wise from a cheaper/more primitive setup on the Festys.
    • #32
      I have only had the FestivaL a few weeks. I have thought that the fan motor is bad as the temp needle fluctuates and it gets warm-er, but the fan sounds like it's not on. After reading here, can someone tell me am I to have the vents to circulate inside air or bring in outside air? And, if I understand, I should set to floor for best heat? I have it on floor/def but it doesnt blow squat. Help
      • #33
        Floor or defrost gets the best heat.
        Sent from my HUAWEI H892L using Tapatalk
        88 Ford Festiva LX "Miogi" B8-ME swapped.
        93 Ford Festiva L "Haywire" Rat infested trashcan WIP
        • #34
          You should hear the fan working.Check for a bad fuse to start with.
          • #35
            If your fuse is good tap on your blower motor it's on the drivers side up and to the right or the gas pedal.
