So I am trying different configurations of struts and strut combinations on the different Festivas we own. I just ordered front shocks and mounts for a 2002 Kia Rio (1.5 L engine) where the left and right struts are different. The intent is to use the Kia struts/mounts with Festiva springs. Before I put the new struts and mounts on, did I order the correct struts. Should I have ordered the struts for the 1.3 L? Thanks.
Front Struts
I have the 01-02 Rio 1.5L struts with Festy springs and brake lines. The brake lines do not go into the little bracket for them on the strut, hence using Rio lines I guess.
I'd recommend getting gen1 Miata front springs from Rock Auto; they are 140# IIRC. That's what I'm switching to in the spring, and would have done it originally if I'd known more then. You might want to cut them one coil, to maintain a proper ride height. Just saying, I don't know from experience.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
