Still got that little squeak or chirp I've had for a month or so.
And feeling my way through the repairs-
so far I've done one half assed outer rear bearing change on one side and a new drum with two new bearings on the other.
Have new races in the other drum and hope to get that on soon-
that'll take care of half the bearings....
After looking at the repair replacing front bearings I've concluded that I can't do that procedure entirely but I may try to get the outer ones on or lubricate them if I get the spindle nut off- anyone know the size of that nut offhand? Aspire, not a Festy.
At any rate the chirp goes on- not yet getting much worse- as the year ebbs to a close. I'm tired and the days are short.
It sounds as if it now might be the front, but I really can't tell when Im driving- so I'm hoping it may last the holidays before I have to get the front replaced and maybe it will disappear after and if I can get to the front outer ones.
I finally decided to try something on the front inner bearings, and that was to attempt to get some oil into them, in fact a small pool of oil if I can. Maybe get into some of the existing grease to work itself around a bit.
To that end I just took a very sharp knife and made a very small incision into the rubber boot near the bearing. Less than 1/4" and it closes itself right back up- you'd have to search to even see it.
Then I took an oil can and thrust the nozzle through the small cut-- and then squirtied 20 or more pumps of oil into the bearing area and boot. I did this on both sides- the oil is probably not that great for the boot, but those are available and not that expensive- If I have the bearings replaced I'd just as soon get new boots on. The boot is stil virtually weather tight , especially here in Florida and I'm sort of a fair weather driver anyway. Mostly I just want to buy time on the bearing repair and the more the better.
I went around the block- I still hear a chirp- it seems a little less, but the results are still inconclusive at this point- no harm in trying I figure, and it may even be possible to fill the boot via a tube of white lithium grease I think you can get in a tube, or better still a grease gun and needle fitting.
anyone ever done this sort of thing and how successful do you think it may or may not be? I'm speculating that if their is not an existing problem already there- like mine- this little slit may keep an expensive and involved repair at bay for quite some time.
