heater hoses conection on festiva 89
  • heater hoses conection on festiva 89
    I have a problem resen buy a festiva and have not heater core hoses and i dont find the manual . Please help me. Sorry for my bad inglish
    You want to hook up the heater core in Mexico?
    Just bypass with a piece of hose.
      The heater core is instaled. But is not conected in radiator.
        Speak spanish
        Sent from my LG-H631 using Tapatalk
          puerto del lado del pasajero entra en la ingesta en la parte inferior .
          DriverSide puerto debe envolver encima de la transmisión en torno a la parte inferior delantera del motor
            Ok muchas grasias. Boy a buscarle
              If the heater core is still in the car but disconnected and by passed it is likely already leaking- you may have to get a new one installed. Tip- run heavier concentration of coolant to avoid heater core rusting and failure. I always run 100 percent straight coolant- and never had a problem. nunca.
              Heater cores often rust faster when a water pump leaks and people keep putting water in, instead of expensive coolant
              The hoses themselves aren't long- 25-30 cm, and "S" shaped. Dos similar. One attaches to a long silver tube- both attach para the firewall -
              under the thottle body and ademas de los injectores.
              Este dos tubes under el throttle body that are connected ahora con hose 25 cm diameter Un a radiator y un a la engine block.- Dos core hose attach a estos y la firewall inlets
              You may be able to find picture aqui if you search that show the hoses-
              behind throttle body here.
                You dont want to run 100% coolant in a hot country. Much less ability to remove heat. Hot spots can/will occur. Although that doesnt seem to affect festivas as much as other cars.
                Hoses were most likely connected because of a leaking heater core like you said but could also be that the PO didnt want any heat at all in the cabin.
                  I got Gates 18710 and 18735 from Rock Auto.
                    Ok guys tanks to all.
                      I find inlet hose but where is return ?
                        The cores are steel? Thought they were brass?
                        Head > core> block I believe?
                        And people need to run distilled water with coolant. Tap water with coolant is just circles for rust prevention.
                        Sent from my One using Tapatalk
                          Heater core is not conected. I tink is nose como c omo se dice laton.
                            Este hose in photoshop es Air Conditioning fitting- cuidado! no es heater inlet- estos es dos connexiones en firewall a detras? -behind- el throttle body- mas derecho 30 cm mas o menos. No es visible en estos photos.
                            El fitting laton es possible pintar- no es seguro. Dos fittings laton de heater core es 5 o 6 cm en separatcion, mas o menos, de yo recuerdo..
                            Los otro fittings - a la radiator y la engine block acerca de heater core inlet y outlet approximo 30 cm para S -shape hoses, y estos es de tapon ahora. Mira los conexionnes tapon en lado el engine block.
                              Lo siento- estos connexiones para radiator y engine block es connected para un manquera-hose- ahora, por a "by-pass" el core de heater.
                              Mirar por este hose, y los dos heater core manqueran connectar alli y a los conexeones de firewall. Pero no reverse. Possible arrow :ia:para idicar este drrecion.
