Every three to four days I have to refill the brake fluid reservoir. I have checked everywhere for leaks. Lines,
junctions, hoses. rear wheel cylinders and the piston for the disc brakes. rear has all new cylinders and from
front piston has new piston rubber seal inside piston. There is no sign of any brake fluid leaking anywhere.
All the repairs and replacements took place in May of this year and since October have had to refill the brake fluid
as mentioned above. Is there something I am missing? I have even had someone pump and hold the brakes to see if
anything showed up......Nothing. I did visual check, but also feeling each area with finger to detect and thing that was
not visible. Has anyone had this problem or a solution? Also no smell of brake fluid on the interior. Please help! Thanks.
