We have a 91 Festiva and we are having issues with it starting. It will fire and run off ether. We replaced the fuel pump and have made sure there is fuel at the fuel rail. When we check the fuel injector wiring there is power at the green wire with the key on and it appears to slightly pulse when cranking. The other wire also shows power when cranking. If we hook the test light to the battery positive there is a pulsing light when cranking on the green wire and nothing on the other wire. We are lost on this one. Anyone have any words of wisdom for us? I hate electrical problems!
91 Festiva question?
Do you have the vaf and intake pipe connected? The vaf is the metal unit that the filter is attached to.
it won't run if there is a leak in the intake pipe. Where are you squirting the ether into the intake?Jerry
Team Lightning
Owner of Team Lightning
93 L Lightning. BP
Originally posted by loser77 View PostSorry guys the holiday kinda took over all spare time. We've got the air intake taken apart between the filter and the throttle body. Will try hooking that back up and trying again. Didn't realize these were that sensitive.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
