no spark at coil
  • no spark at coil
    i have no spark at my coil . any ideas on what could be the problem? what could casue no spark from the coil? i know it could prob be a million things but what are the most common?.
    1993 B6T swapped Festiva- Reich raceing ECU, Cork Sport down pipe, MBC for now, Capri Tranny. sold
    1993 BBF 466cid mustang notch 7.7 ltre
    festiva turbo b18 project
    2001 BMW 325i
    1996 ford F-150 sold
    I have no idea what car or year we are talking about .
    I am moving this to repair help
    Timing belt
    Crank sensor
    dist.
    bad or corroded connection (s)
    HD2500 Duramax Chevy
    Z28 LS1 power 500 +
      I had that happen to me before, and what happened to me is that the cam siezed up from a bad oil pump, so when the cam siezed, the cam pulley kept on spinning and broke the key pin at the end of the cam. Take your cap off of your distributor and turn the motor over, if the rotor doesnt spin thats probably your problem......thats how I found out :?
      Mike
      http://www.cardomain.com/ride/2162509
      First known g25mr with Hydraulic clutch swap
        I had that sort of problem with my 93. Turns out that I was getting spark from the coil but it was jumping the (cheap-ass) wires that I had gotten. Upgraded to better wires and that solved the problem. Easiest way that I found to test for jumping was to wait until dark and try to turn over the engine. If it is jumping..you will see it.
          93 festiva with 91 b6t. i tested and i have current at the coil but no spark at the plugs any ideas?
          2001 BMW 325i
            figured out the prob.. ihad 2 ground wires i didnt see.
            2001 BMW 325i
