Ignition switch and wiring harness
  • Ignition switch and wiring harness
    There are 2 wires that go into a small plastic box on the underside of the assembly.If these get pulled out what is the best method of repair?
    Those are for the "key in left in ignition"alarm and can be capped with no effect except loss of that warning. I had them pull out and don't know if it's repairable. In my case the box broke open and didn't seem that it would be repairable. If you buy a new replacement from Fourgreen, it's not present nor is the other two wires in the white 4 wire plug. The other 2 wires are "panel brake lamp test" which lights the "brake lamp" when the ignition is in the start position.
    "Wenona"-89L parts car
      thanks for the info it is helpful
