B3 Timing cover
  • B3 Timing cover
    Is it a common thing for the plastic timing cover to warp? Mine warped. PO said she replaced it and it warped again cuz it just does that, but recent, umm... discoveries... Leave me doubtful of anything I was told. But, if that is the case, does anyone have any custom work or anything they can post? Thanks guys
    A mechanic knows how; A technician knows why.
    Wrecked. Repairs in Progress"Frankie" 1957 Chevrolet 3100, NA 2bbl 283cuin, Muncy Granny 4sp, 3.90 Open Diff @ ~95K miles
    Wrecked. Repairs in Progress"Alice" 1991 Ford Festiva L, NA EFI B3, 5sp @150k miles
    Reassembling"Aurora" 1991 Ford Festiva L, NA EFI B3, 5sp @240k miles
    FB Festiva page: Jared Bennett
    Instagram: jaredbear82
    It is not uncommon for people to cut out the center of the upper timing belt cover, leaving enough on front, top and upper rear to do some good, but eliminate the rubbing on the water pump pulley. This also lets you check your belt timing without removing the cover.
      This is my concern
      Should I be worried about debris getting in there and causing damage? I spend a lot of time driving on dirt
        Here are the Kia part numbers in case you decide to order them from Four Green.
