Removing tie rods on '91 manual rack
  • Removing tie rods on '91 manual rack
    Does anyone know of a specific tool (or makeshift way) to remove the rolls pins from the blind hole in the manual rack so I can replace my Tie Rods?
    A mechanic knows how; A technician knows why.
    Wrecked. Repairs in Progress"Frankie" 1957 Chevrolet 3100, NA 2bbl 283cuin, Muncy Granny 4sp, 3.90 Open Diff @ ~95K miles
    Wrecked. Repairs in Progress"Alice" 1991 Ford Festiva L, NA EFI B3, 5sp @150k miles
    Reassembling"Aurora" 1991 Ford Festiva L, NA EFI B3, 5sp @240k miles
    FB Festiva page: Jared Bennett
    Instagram: jaredbear82
    Shoew a picture of what you mean! I just replaced both inner and outer in my rack. I might be able to help you.
    19?? 150$ burnout car SOLD
    1991 (STRESS RELIEF)SOLD
      Unscrewing the inner from the rack shaft will force the pins out. Don't scar the shaft!
      No car too fast !
        Yep I just unscrew the rods like there not even there. Didn't even know they where their the first time I did mine.
        I use a pipe wrench on them though because I could not get enough leverage with a wrench.
          It's easier with special tools, but not required. Good fitting wernch, wrench extension, and copper /brass hammer, aluminum vice jaws, it'll go
          No car too fast !
            If I just unthread the tie rod, hoping it pushes out the roll pin, will I be able to put in the new pins?
              Yes, after installing the new ( or used other) side rods, drill 6mm deep and fit new pins.
              No car too fast !
