Put on new master cylinder and brake booster. Bled brakes on all four wheels.
When depressing the brake peddle I have very little braking, the peddle goes almost
to the floor. When I bled the brakes, I had no air in the brake fluid at all. The fluid ran clear
four times. All fittings are tight, loosing no fluid level in the reservoir except when bleeding each wheel.
Now I have done this a million times before and never ran into this problem. Could it be the proportioning valve?
Any help, however absurd, would be appreciated.
