so i have a 91 festiva manual trans i was told that the engine was rebuilt within the last 2 years im concerned about how good of a job they might have done everything was running fine then all of a sudden first started lurching a bit thought it was operator error being this is my first time in years on a manual then 3rd and 4th assuming 5th too but car stoped staying running before i got to find out if i give it gas just right i can keep it revving to keep it running try put it in gear dies within seconds if i nail the gas otherwise dies immediatly not sure where to start troubleshooting at this point any suggestions are greatly appreciated thanks
91 festiva started lurching in low gears then all gears wont stay running need help
Your first photo clearly shows a crack in the intake pipe. This allowing unmetered air into the system which is probably the main cause of your issues.Originally posted by twitchy89 View Post[ATTACH=CONFIG]19220[/ATTACH][ATTACH=CONFIG]19221[/ATTACH]Ian
