Hello, I have removed my rear shocks and need to replace the bolts on each side. Can someone provide the size and grade? Thanks for your assistance, Al in Alsip, IL
Rear lower shocK bolt size...
take the bolt to the local hardware store. They normally have a bolt thread checker on the shelf. Check the thread buy a bolt thats the same. I would try to get grade 8.1990 (LUCIFER 2.0) fully built BP+T with E153, Fueltech FT500, traction control with hopes of 600hp (i drank to much of the KOOL-AID)
19?? 150$ burnout car SOLD
1991 (STRESS RELIEF)SOLD
I have been to O'Reilly, Napa - no longer carries grade 8, and Home Depot. Bolt end was exposed and very corroded. We tried their checkers and non fit right. I am guessing it's an M10-1 x 60 mm.Last edited by FordFestiva; 03-10-2016, 01:52 PM.
Assume the old bolt was clean going into the store checker? I'd clean the threads with a wire brush. I restore a lot of rusty old bicycles and it really helps to clean the threads.
For hard bolts look for three raised dashes on the head.Original owner of silver grey carburetted 1989 Festiva. 105k km as of June 2006. 140k km as of June 2021.
I have a bag of them at home, I can get the dimensions when I am done with work. Need to work in the shop tonight anyway, so I should remember to get the size.The Festiva Store
Found this quickly, with a simple search.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
Bolt Size: M10-1.25 X 70mm Class 10.9
Advance Auto Part # 99102070 comes with a nut too
Thanks TominMO!
I searched rear shock bolt, but did come across that thread - reason being, listed as rear strut when actually it is a shock.Last edited by FordFestiva; 03-10-2016, 06:38 PM.
I noticed the price of that bolt was 1.29 5 years ago and is now 1.79.
I don't know about you but my social security and retirement benefits sure haven't gone up 39% since then and I suspect most people haven't had that big of a raise at their work either...
but then hedge billionaire Jeff Smith needed a raise so he can take over Yahoo and add it to his Starboard Value LP hedge fund portfolio. hmm.. maybe the Advance Auto Parts employees go a big raise.
Thanks for this info.. I needed one of these to replace the one I drilled through getting my right strut off Rosie.Last edited by 1990new; 03-10-2016, 07:45 PM.
I'm used to thinking of shocks as totally separate from springs, like the old days before we had FWD and struts. To me, a strut is when the spring is on top of the shock. In front they are called MacPherson struts, but in the rear it is called a Chapman strut, but only if the rear wheels are driven. But some people use the word shock for any type of strut or shock. Rock Auto lists some of the rear struts as "shock absorber", but that's erroneous I think. Mostly they lump the FWD fronts and rears together in their listings as struts. It probably confuses things that coilovers are thought of as shocks, whether on front or rear.Originally posted by FordFestiva View PostI searched rear shock bolt, but did come across that thread - reason being, listed as rear strut when actually it is a shock.
Long story short--use both terms when searching! :-)Last edited by TominMO; 03-10-2016, 07:46 PM.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
I use 10mm-1.5x70 8.8Z I have a bag of nuts to match because i normally cant reuse the factory nuts anyway. The biggest thing is making sure it is 10mm and 70mm long and use a matching nut.The Festiva Store
Thanks to all and I wish everyone the best! We need to stay united and preserve the love of these precious Festivas.
The major difference between shocks and struts is that a strut is a structural part of the vehicles suspension system where a shock is not.
FYI - I used lots of PB Blaster, wire brushing, and wound up cutting the shock off as listed in a previous thread.Last edited by FordFestiva; 03-10-2016, 11:30 PM.
So what was said earlier was its a m10x1.25 bolt and you use an m10x1.5 and grind off the captive nut and use your own nut?Originally posted by nonamekid View PostI use 10mm-1.5x70 8.8Z I have a bag of nuts to match because i normally cant reuse the factory nuts anyway. The biggest thing is making sure it is 10mm and 70mm long and use a matching nut.
