On both my lower strut mounts, the captured nut broke off. I replaced the bolt and nut with hardware store ones. My bolt has a 17mm head, and the nut takes a 5/8" box wrench. I took the strut to the store to get the right diameter. Forget the length, but you can use the original one to compare. I think it's a little bit longer than stock, maybe by 5 - 10mm.
Luckily, it is pretty easy to get the box wrench into the rear of the beam to thread the nut onto the bolt. Use a little piece of duct tape to hold the nut to the wrench. And have a magnet handy, one of those on the end of a telescoping tube, for if/when you lose the nut in the beam.
