One of the risks you take when installing used air conditioning components is that they may be defective. That being said, I have a problem with some component(s).
The A/C is not cool enough. There are no refrigerant leaks, the pressure on both sides is correct, I have a working recevier drier, and no electrical problems. When the system was first pressurised, all was well. The low-pressure pipe used to condensate with moisture, and things behaved as they should. Now it seems that barely any cool air comes through the vents. The high pressure line is hot to the touch, and the low pressure line is somewhat cool but I'd say it's around 50 degrees or so. It's not enough to make it condensate or anything, like it should.
The system also makes a lot of hissing, which makes me wonder if I have a bad thermostatic expansion valve.
The compressor might be another possibility but I doubt it since the idle bogs down whenever the A/C is on.
Any thoughts or opinions?
Regards,
Tim
Regards,
Tim
