So my festiva my b8-me swap has been running good and strong but today it seemed to lean out and shut off on me while driving. So I checked my fuel it was good got fuel coming out of the injectors. So then I checked spark. Got spark checked timing and I got timing set ignition and belt. Darn thing still wo t start. It sounds like it always does when cranking but going to do a compression test tomorrow. Just looking for ideas as to what could be wrong. Darn thing won't even sputter. I also tried changing out my coil. I have spark at the plugs. It seems it has everything it needs to run but just won't start. Could it be a bad dizzy sending the signal late or early to the coil? Going to try a spare vaf and dizzy tomorrow too. Fuses are all good as well.
Sent from my HUAWEI H892L using Tapatalk
