I posted this in my Rosie Project thread but put it here in the Help Form also:
Got the injector seals in the mail today and the rail is back on with no leaks but....no start yet.
Leading up to this point.
Installed the timing belt:
Lined up the 12 and 3 oclock marks on the cam pulley and the lower mark dead on in the sprocket valley and installed the belt.
Turned the engine over a few time and belt line up appears to be good.
Confirmed cylinder 1 is at TDC when the marks line up.
Confirmed that the rotor button is at the number 1 plug wire when cylinder 1 is TDC
With number 1 plug out I confirmed that I get a spark when engine is turned over.
I also know the compression is good on all cylinders.
I also check the resistance on all 4 injectors and they are all between 14.8 to 15.0.
Turned over several time but the engine has not fired once.
I know I'm getting fuel at the rail but how can I check for fuel in the combustion chamber without remove the fuel rail again?
