My 1990 Festiva has been giving me nothing but problems since I got it. I rebuilt the engine so it at keast has compression, but now it seems to be plagued with electrical problems. It will start right away, but then die right after. It takes about 10 minutes of starting it and then pumping the throttle to keep it from dieing. After that, it won't idle and it dies if I go WOT. I probed the tps to see if it had the cirrect ref voltage and it did, but the sig wire was flipped with ground and had 12v on it. I suspect the computer, but after buying one off ebay it still does the same thing. So far I've replaced the computer, tps and ect to no avail. Does anyone have any other ideas?
Hard start, won't idle and dies at WOT
Tps on the Festiva is a 3 position switch (idle run wot), not a potentiometer. Do as William suggests first and report.Trees aren't kind to me...
