90 auto festiva stalls every morning 2 or three times and will drive sluggish for first couple of minutes and then after it warms up it idles fine and doesn't stall. I have replaced coolant temp sensor and unplugged the iac while running and idle changes as I connect and disconnect so that appears to be working fine. Only after the car sits for a couple hours is when I have the issue. Fuel pump and gas tank were replaced by previous owner not sure about filter. Other than that issue car drives fine once warm
Morning start up issue
First thing I'm thinking of is the IAC (idle air control) may be bad.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
Iac appears to be working fine significant idle change while unplugging and plugging back in. I removed the intake to discover a significant amount of oil gatherd in the accordian section. I am thinking that is affecting the maf sensor causing the issue but I'm not sure I'm kind of stumped I removed the iac and cleaned it out today so I guess I'll see what happens tommorow morning
Have you checked engine compression? Excessive blow-by caused by ring wear can cause low compression, rough idle and oil in your intake tube. You don't a MAF sensor as more modern cars have. A Festiva uses a vane air flow meter that measures air by the opening and closing of the vane.
Sent from my iPhone using Tapatalk"Fred" 93 Festiva L B6-ME Swap
“Though he is small, he is but fierce.”
Rebuild! Upgrade! Both!Trees aren't kind to me...
Originally posted by Swilliams View Postlow compression in cylinder 4 turns out that was the issue all along...... now what to do with this thing
If rings, then your only option is to install a turboed BP......90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
carbon buildup on valve will cause leak and might be cured with chemical cleaning. worked for me. I could see carbon on the underside of the valve cover indicating leaking exhaust valve. used a chemical cleaner before changing oil. cheap cure.Last edited by WmWatt; 05-18-2016, 08:46 PM.Original owner of silver grey carburetted 1989 Festiva. 105k km as of June 2006. 140k km as of June 2021.
Pull the head, the pan and pull the cylinders. Due to the age and mileage, they're likely just stuck. That's all I had to do with Skippy, aside from a burnt valve, but that was a different issue.Trees aren't kind to me...
Originally posted by Swilliams View PostLooking like rings .... I put some oil down the cylinder and re checked that cylinder and compression immediately went up .... Car has 48,000 on itLast edited by TominMO; 05-19-2016, 08:25 AM.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
