Hi all was wondering if anybody else has had this problem, my 89 weber carbed periodically ends up with some oil spray in the air cleaner area. It is coming from the hose that runs up from the valve cover, i believe it is called a crankcase breather hose. I have the original air cleaner holder slightly modified to fit the weber, i had this problem before i did this rebuild but i knew i had a bad cylinder, it was so bad that i could not rebuild that motor, i got another b3 and rebuilt it, it has around 30,000 on the rebuild. I have checked compression and all cyclinder check out pretty high. Soo im not sure what us going on, as i said it only happens once in a while i will clean it out check it every week and sometimes its 2 weeks between incidents other times it goes 4 to 5 weeks between incidents this is my dd and gets at least 500 miles a week put on it.
Thanks ahead of time
Uglyed and the Steve
