Question for you guys: i am changing my transmission and clutch and throw out bearing right now. I was expecting the pilot bearing to be worn or feel a bit rough, but it feels perfect. The clutch kit i bought has one, but it looks to be of questionable quality. The kit was super cheap 'autocom eco clutch kit' off ebay. New bearing has soft rubber sidewalls, oem one thats in there has metal sidewalls and says 'made in japan'.
would you replace it? Do pilot bearings ever actually fail on these cars? I didnt find anyone with failed pilot bearings when i did a quick forum search.*
Also the crank seal by the flywheel. I have a new one, but the oem one is not leaking. Should i replace it or leave it? I dont want to change it if i dont need to, so many things went wrong today i dont want problems getting that seal in :p Car only needs to get me another 65,000km (40k miles) but i cant have any leaks or failures in the last half of that.*
Thanks for any help.*
would you replace it? Do pilot bearings ever actually fail on these cars? I didnt find anyone with failed pilot bearings when i did a quick forum search.*Also the crank seal by the flywheel. I have a new one, but the oem one is not leaking. Should i replace it or leave it? I dont want to change it if i dont need to, so many things went wrong today i dont want problems getting that seal in :p Car only needs to get me another 65,000km (40k miles) but i cant have any leaks or failures in the last half of that.*
