This is one I learned a long time ago.
What you do is mix a small amount of transmission fluid with an equal amount of ACETONE
The acetone helps percolate the transmission fluid into the joint, and the transmission fluid breaks up corrosion and lubricates.
*Marvel Mystery Oil can be used in place of trans fluid, and the acetone evaporates after a while
