Originally posted by fezzy
WOT use:
ATF in a Mazda 1985 RX7 RWD transmission for racing was a total fail. A friend used it based on comments from circle track guys, and it destroyed the synchros and seals in one day in his road race car. I rebuild them, and he gave it to me to take apart. The synchros were worn to nubs, and oil dribble-leaked out of all the seals. There was lots of grey goo in the oil and on the magnetic capture plug too, indicating a lot of gear wear. In one day!
Redline MT-90 works well in the same transmission (a 75W90 gear oil with various additives). There could be something better, and I have seen comments on the Spec Miata forums (basically the same transmission with minor updates) that a variety of other more expensive choices might be better. Motul transmission oils are suggested, and Torco racing tranny oils, but it all comes out as opinions as to which is better. Anyhow, in racing ATF was a disaster, and Redline is a great safe fallback even if there could be something better.
I use Redline MT-90 in the FWD G25mr tranny in my winter raced ice racer, as it simply does not get as hot as in summer racing, and it starts from way colder. It works very well, shifts well, wears well. Oil changes once a season do show some brass from the synchros, but not a lot.
I have rebuilt G25mr, the e-series, 1980's RX7, and 99 Miata. Inside they all look like a Mazda sourced design, but I can't judge tolerances and maybe there are some differences there. But aside from the change in geometry for FWD vs RWD they look pretty similar, with an identical synchro design (except second in the 99 Miata), same cone angles, similar preloads on the bearings. So I think what works in one should work in the other for the transmission. Of course, there is also a diff in the FWD, but it does not use the same design ring and pinion, hypoid gear of the rear diff in the RX7, so it should be fine with the same gear oil as the tranny.
Redline shows the 75W90 gear oil is about the same weight as 10W40 engine oil. So the 20W50 engine oil Advance is using is higher viscosity still.
The additive difference between engine oil and transmission oil is important, and makes automobile engine oil seem a poor choice, but as Advance points out, motorcycle engines are special, so their additives may be better adapted to a transmission's needs. His low wear certainly suggests it works in WOT conditions.
Street use:
Manufacturer says ATF, they can't be totally wrong. But the WOT experience I have with ATF above says I would never choose to use it in any circumstance for a manual transmission.
Manufacturer says gear oil is good in Australia for the same tranny. Redline MTL works well racing, it is a good gear oil, it should work well on the street too. Other companies make similar mixes, and it is pretty hard to get really good data to choose between them, while on forums flame wars are fought over redline vs amsoil vs Royal Purple, with little hard evidence. For the street I suspect any of these will give the same performance and life. Certainly the Penzoil Synchromesh mentioned in this thread has good looking specs.
