Hello Everybody!
Got home from work the other day, shut my car off, and the rad fan kicked on. Turn the key back on and it quit running. Turn the key back off and it started running again, I had to unplug the fan to get it to stop. Let the car cool down, plug the fan back in and it starts running. Fire the car up and the fan works normally, turning on when I started the AC and working when the temp is up. Turn the car off and the fan runs constantly. The relay appears to be working, it is open with the key off and closed when I turn the key on, is that normal? Couldn't get to the JY yesterday to see if I could find a different relay. Anyone ever had this issue? I could wire a switch into the circuit but my car is fairly clean and I'd rather not do that, it would drive me nuts! Any help or suggestions are greatly appreciated!!!
