Hello all. I have a '91 Festiva L 5-speed and recently changed the valve cover gasket. During the process I had to take the throttle body off the valve cover and set it on its side on top of the engine. Didn't disconnect anything else except for the four bolts that keep the piece on that's in the way of taking the valve cover off..
When all was said and done and put together I started the car and am having issues with the car staying revved and coming down slowly even after I let off the gas..
I've ruled out a vacuum leak in the lines.
Anyone have similar issues and have fixed them or any suggestions on what to check next? I've tightened the throttle cable so there is no slack.
Thanks!
Sent from my iPad using Tapatalk
Thanks!
