Picked up the Festiva this weekend, Festiva owner for the 5th time. Dad got a Spark so didn't need 2, and this one has seen better days. It has a new one from me. I changed the both front hubs out a month ago from my old automatic which was I thought was good and the growl is still there. Also had to work on the back brake's so I know those are good also. Did the touch test and the back ones were cool to the touch, the drivers front was a tad bit cooler than the passengers front.
It sounds like it's coming from the right side. Definite bearing growl and changes with speed. The tires are new on the front, and the transmission is full of new fluid. Alignment must be pretty close as it doesn't pull and rides pretty good. Think there is a bad tire on the back though.
Could it be internal to the transmission or should I try another hub? In the past I just got different hubs and problem solved. Thoughts?
