Fuel gauge reading empty
    Something is seeing a switched short to power... After the brake switch.
      It's wierd. I have no idea where to start. I still think cluster is bad for the fuel and temp gauge. It was not working before it started this.
      1990 Red Festiva STOCK "pregnant roller skate"
      1989 Yellow Festiva BP swap "Freebird"
      2007 Ford F150 "black sunshine" full exhaust with x-pipe. K&N intake. Headman Headers.
      2001 Honda accord SOLD lots of goodies done suicide doors lowered 20 inch rims
      2005 Ford F250 6.0 Turbo Diesel "swamprat" 4 inch lift, 4 inch mbrp exhaust, egr delete, glowshift pillar gauges.
      1994 Ford F150 5.0 Completely stock.
        Here you go !
          Thanks bravekozak. Probally going be needing that. I gotta figure out my password so I can sign on computer to print that.
            I had a badly corroded tail light socket cause strange things to happen with some of the lights in the cluster. When the brakes were applied, the left directional indicator and other lights would come on, I don't remember which ones now. Replacing the left tail harness fixed it.
            "Blue92"- 92L 5 spd, original owner- 185K, B8,DD..
            "Pedro"-88L 5-spd, B6D (built by Advancedynamix)
            "Blanca"-92 GL auto, 125K(FM8 Lowest Miles)- B6 daughter's DD
            "Tractor Blue"- 89 L auto, 110K
            "Chester"-88 LX, runs but not street legal
            "Wenona"-89L parts car
            "Flame"- 89 LX 5 spd ,parts car
              I think I may start with that then. Be easy to change.
                Unplug your taillight harnesses one at a time to see what happens.
                Also unplug and jump your dimmer switch to see what happens.
                  Ok. Probably be weekend before get a chance to do anything. Deer season in now I don't do to much car work then lol.
                  • #24
                    Thanks. I figured out the lights deal. My dad when he was driving it had wired trailer lights into the taillights and they were grounding out. I took that out and fixed the light issue. So now just the fuel and temp gauge all is left and I believe that to be the cluster.
