My 90 festiva will warm up and then when I sit in idle in neutral it will start stumbling and then dye anyone else have this problem before and how did you fix it
Are your lights dimming when you turn on the headlights? = Possible alternator and can drop RPM enough to kill it
Does it run rough when at normal idle? = Spark plugs, wires, with age need replaced. Give it a tune up
Dan
