I'm about to replace the front Rotors and Bearing on both Festivas for the first time. I have the write up on how to do it and I'm purchasing all of the parts but I'm getting slightly confused. I ordered Front inner and outer wheel seals but I also see a category for an Axle Shaft Seal. Is this something that I need to order as well?
Axle Shaft Seal Question
Last edited by firebush357; 11-07-2016, 11:27 AM."The White Turd" 1993 Festiva 144k miles. (Winner of FOTM November 2016)
https://drive.google.com/file/d/0BzM...ew?usp=sharingTags: None
So after a Google Search I realize that these are for the Transmission side. I have replaced CV Axles before but have never changed that seal. Does anyone know how difficult they are to remove and replace?"The White Turd" 1993 Festiva 144k miles. (Winner of FOTM November 2016)
Easy as pie... Just pull out the old one, clean the area thoroughly, lubricate the edges of the seal and push it in. Best to use a large socket that matches the sizes of the edge but, but I have just tapped them in with a little hammer around the edges with no problem. Just be careful not to damage the lip where the axle goes in.Originally posted by firebush357 View PostSo after a Google Search I realize that these are for the Transmission side. I have replaced CV Axles before but have never changed that seal. Does anyone know how difficult they are to remove and replace?
RockAuto is showing a Centric Brand being the cheapest but they have a Front Inner, Front Outer, and Rear Inner. I have tried to find some info on the sizes but there doesn't seem to be any, I did find some pictures but they look exactly the same to me... Any suggestions?"The White Turd" 1993 Festiva 144k miles. (Winner of FOTM November 2016)
Sorry, I thought you were talking about the axle seal that goes in the transmission.Originally posted by firebush357 View PostRockAuto is showing a Centric Brand being the cheapest but they have a Front Inner, Front Outer, and Rear Inner. I have tried to find some info on the sizes but there doesn't seem to be any, I did find some pictures but they look exactly the same to me... Any suggestions?
Rock Auto shows These for the front. One on the inside and one on the outside. you have to take the hub apart to replace them and once you get the hub apart (I assume to replace the bearings) they are ease to put back in. There is only one inner seal for the rear wheels. You have a grease cup on the outside of the rear wheels.
BECK/ARNLEY 0523196 {Click Info Button for Alternate/OEM Part Numbers} Info One of our most popular parts
Front Inner
Choose:
$0.48
Add Part
BECK/ARNLEY 0523197 {Click Info Button for Alternate/OEM Part Numbers} Info One of our most popular parts
Front Outer
Choose:
$0.48
Add Part
I am talking about the Axle Seal that goes into the Transmission, that is why it is confusing me because there shouldn't even be an option for a rear seal."The White Turd" 1993 Festiva 144k miles. (Winner of FOTM November 2016)
Thats an odd section, not sure why they have seals there. Go to wheel/hub and click on wheel seals. Inner and outers for the fronts are there as well as the rear. Then go to transmission and click on seals and the output shaft seals are there. You can compare part numbers from that drivetrain section if you like, i didnt do that
Thanks"The White Turd" 1993 Festiva 144k miles. (Winner of FOTM November 2016)
When I replaced mine several years ago, Autozone listed a different size seal for each side of the trans, mine were the same size.Jerry
Team Lightning
Owner of Team Lightning
93 L Lightning. BP
Since the axles for the manual and auto differ the seals probably do too so check that you order the correct ones.
Also only do one axle at a time to keep the innards of the transmission from collapsing into a heap inside.Original owner of silver grey carburetted 1989 Festiva. 105k km as of June 2006. 140k km as of June 2021.
It is confusing... I should know by now since in the past year I have change those seals in two automatic and 1 5 speed transmission while working on Rosie.
I know that for the Manual I ordered these seals from RockAuto:
TIMKEN 223543 {Click Info Button for Alternate/OEM Part Numbers} [Main / Output Shaft Seal] Info
Left; 5 speed trans.; Trans. code MTX
TIMKEN Warranty Information
12 months
Previous Image
Next Image
2 Request Warranty Replacement
TIMKEN 2007N {Click Info Button for Alternate/OEM Part Numbers} [Main / Output Shaft Seal] Info
Right; 5 speed trans.; Trans. code MTX
I ordered two of each because of my experience with changing the ATX 3 times before switching Rosie to a 5 Speed.
I now have those two extra ones. I just entered them in a RockAuto order that they would cost you $10.63 including shipping and they show them arriving 11/16.
If you send me $8 I will get them in the mail to you tomorrow and they would get to you on Thursday at the latest.Last edited by 1990new; 11-07-2016, 10:15 PM.
The 2007N is called for on both sides for the ATX but only on the Right side for the 5 Speed.
The 223543 is called for on the Left side for the MTX. While the 2007N would fit on the left side,
the 223543 is a little wider base and has a narrower lip than the 2007NLast edited by 1990new; 11-07-2016, 10:49 PM.
I just ordered one of each last night but If I need anymore when I eventually do the other car then I will let you know.
Thanks!"The White Turd" 1993 Festiva 144k miles. (Winner of FOTM November 2016)
