Axle Shaft Seal Question
  • Axle Shaft Seal Question
    I'm about to replace the front Rotors and Bearing on both Festivas for the first time. I have the write up on how to do it and I'm purchasing all of the parts but I'm getting slightly confused. I ordered Front inner and outer wheel seals but I also see a category for an Axle Shaft Seal. Is this something that I need to order as well?
    So after a Google Search I realize that these are for the Transmission side. I have replaced CV Axles before but have never changed that seal. Does anyone know how difficult they are to remove and replace?
      If the axle is out it is a simple screwdriver to pry the seal out
        Easy as pie... Just pull out the old one, clean the area thoroughly, lubricate the edges of the seal and push it in. Best to use a large socket that matches the sizes of the edge but, but I have just tapped them in with a little hammer around the edges with no problem. Just be careful not to damage the lip where the axle goes in.
          RockAuto is showing a Centric Brand being the cheapest but they have a Front Inner, Front Outer, and Rear Inner. I have tried to find some info on the sizes but there doesn't seem to be any, I did find some pictures but they look exactly the same to me... Any suggestions?
            Sorry, I thought you were talking about the axle seal that goes in the transmission.
            Rock Auto shows These for the front. One on the inside and one on the outside. you have to take the hub apart to replace them and once you get the hub apart (I assume to replace the bearings) they are ease to put back in. There is only one inner seal for the rear wheels. You have a grease cup on the outside of the rear wheels.
            BECK/ARNLEY 0523196 {Click Info Button for Alternate/OEM Part Numbers} Info One of our most popular parts
            Front Inner
            Choose:
            $0.48
            Add Part
            BECK/ARNLEY 0523197 {Click Info Button for Alternate/OEM Part Numbers} Info One of our most popular parts
            Front Outer
            Choose:
            $0.48
            Add Part
              I am talking about the Axle Seal that goes into the Transmission, that is why it is confusing me because there shouldn't even be an option for a rear seal.
                Thats an odd section, not sure why they have seals there. Go to wheel/hub and click on wheel seals. Inner and outers for the fronts are there as well as the rear. Then go to transmission and click on seals and the output shaft seals are there. You can compare part numbers from that drivetrain section if you like, i didnt do that
                  Thanks
                    When I replaced mine several years ago, Autozone listed a different size seal for each side of the trans, mine were the same size.
                    Jerry
                    Team Lightning
                    Owner of Team Lightning
                    93 L Lightning. BP
                      Since the axles for the manual and auto differ the seals probably do too so check that you order the correct ones.
                      Also only do one axle at a time to keep the innards of the transmission from collapsing into a heap inside.
                        It is confusing... I should know by now since in the past year I have change those seals in two automatic and 1 5 speed transmission while working on Rosie.
                        I know that for the Manual I ordered these seals from RockAuto:
                        TIMKEN 223543 {Click Info Button for Alternate/OEM Part Numbers} [Main / Output Shaft Seal] Info
                        Left; 5 speed trans.; Trans. code MTX
                        TIMKEN Warranty Information
                        12 months
                        Previous Image
                        Next Image
                        2 Request Warranty Replacement
                        TIMKEN 2007N {Click Info Button for Alternate/OEM Part Numbers} [Main / Output Shaft Seal] Info
                        Right; 5 speed trans.; Trans. code MTX
                        I ordered two of each because of my experience with changing the ATX 3 times before switching Rosie to a 5 Speed.
                        I now have those two extra ones. I just entered them in a RockAuto order that they would cost you $10.63 including shipping and they show them arriving 11/16.
                        If you send me $8 I will get them in the mail to you tomorrow and they would get to you on Thursday at the latest.
                          The 2007N is called for on both sides for the ATX but only on the Right side for the 5 Speed.
                          The 223543 is called for on the Left side for the MTX. While the 2007N would fit on the left side,
                          the 223543 is a little wider base and has a narrower lip than the 2007N
                            I just ordered one of each last night but If I need anymore when I eventually do the other car then I will let you know.
                            Thanks!
                              My seals were shot before I replaced them with new ones.
