Guys,
My 1991 festiva is leaking oil like a sieve. The whole engine is soaked from top to bottom, engine bay soaked, oil leaking onto the hot exhaust STINKS, loosing about a liter every 4 days.
When I bought it 4 years ago, it leaked oil, so I replaced the oil pan gasket and valve cover gasket. That mostly helped, but there was still a leak somewhere at the front as the alt and crank pulleys and belt were still flinging oil up on the hood underside. Just having taken it apart, I wasn't about to do it all over again for the crank seal.
Fast forward 4 years to the top of my post.......
I have a new valve cover gasket and O rings, a new oil pan gasket, new front main crank seal, new camshaft seal. I plan on replacing all of them and using sealant in the corners of the oil pan to block gasket. [ this is not my first engine oil pan gasket change ].
I know that there is still the oil pump housing gasket, and the rear main seal. Are there any other places for this engine to leak oil? Distributor housing??
I don't think that a leaking rear main seal is going to bathe the whole engine in oil?? So I don't think that is it. I'll leave it alone for the time being as it is alotta work to change. Mine is an automatic trans BTW.
I'm not 100 percent sure the front crank seal needs doing, as the timing belt itself is dry, but there is oil all over on the inside of the timing cover / engine front. How it got there? maybe leaked in from the valve cover? The timing cover dust seal is toast and the water pump pulley has worn through the bulging timing cover......more points of possible oil entry.
Also........ the black plastic air intake plumbing and all of its joining tubes are loaded with engine oil? Right to the air box at one end and to the throttle body at the other end. I've noticed this before and cleaned it out twice in the past. The PCV is working fine........I clean it out and the little check ball rattles when I shake it........... so WHY is this engine oil getting in there?
Thanks for your thoughts!
I like my festy but it IS pissing me off.
