So I've used the search for a simple removal thread of the stock guts & found no relevant hit. So I'm looking for the easiest way to pull the motor/automatic tranny. Location of bolts/pics would be a plus. Don't have a lift would prefer to drop it on the ground where she sits then torch the front end off at the firewall. Only want the hiney of this box LOL. Any help is appreciated & sorry if there is a thread I looked but couldn't find one but then again this old man sucks at googling/hash tags & all that cool kid stuff
B3/Tranny Removal
If that's all you're after, then cut the heater core hoses and fuel lines, remove the rear crossmember bolts and get cutting! The rest will come away clean if you support the 2 halves.Trees aren't kind to me...
Just the outer tie rod ends.
I'm also assuming you don't care about the harness, because that will be dismembered when you cut.Trees aren't kind to me...
I would go with a sawsall, and Diablo blades... Less hazard and a cleaner cut... Faster too.Trees aren't kind to me...
Thanks for the help man!
