Originally posted by ryanprins13
Front shock/strut spring---shock/spring combo?
Timothy, if you budget allows, try to get moog suspension parts. I've had much better luck with them than the cheaper brands.Jerry
Team Lightning
Owner of Team Lightning
93 L Lightning. BP
I'm ordering strut mounts and everyone that offers them offers them with a bearing. From what I was reading in this thread the advantage of going with the Rio strut was getting the bearings.
So why isn't everyone just ordering the Festiva strut mount when it comes with the bearing?
Never seen a Festiva mount with a ball bearing, all I've seen have a friction type disc. That doesn't look like a ball bearing in the pict, looks like the friction disc to me. The ball bearing is in the Rio mounts.Last edited by Team Lightning; 12-28-2016, 08:16 PM.Jerry
Team Lightning
93 L Lightning. BP
Thank you for the help, I'm still getting used to the correct terminology. Can you check out one more link. It is from O'reilly's and it says it includes a bearing.Originally posted by Team Lightning View PostNever seen a Festiva mount with a ball bearing, all I've seen have a friction type disc. That doesn't look like a ball bearing in the pict, looks like the friction disc to me. The ball bearing is in the Rio mounts.
Got all my parts and I'm doing the install right now. I went with the most economical choices for parts. I bought $16 strut mounts at Orielys. I'm confused because things are fitting properly. The bearing is supposed to mount into the top hat , but this part is not fitting because the bearing it came with is too large.
I'm getting frustrated and want to put my car back together. Can I just nix the bearing and go buy a couple of large washers?IMG_0390.jpgLast edited by Timothy; 12-30-2016, 01:21 PM.1992 Ford Festiva 1.3 L 4-cylinder
Yup, with a dab of grease on each side.Originally posted by Timothy View PostOr I could just use old friction plates out of old strut mount.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
Hey I have a 1989 festiva and I need to do the same thing do you have a list of parts?Originally posted by Timothy View PostThanks Tom. That's what I I end ended up doing. I got half the car done now. Hopefully by tomorrow I'll be all done. [ATTACH=CONFIG]20393[/ATTACH]
Sent from my Z970 using Tapatalk
Check out this Forum Post it will have links and stuff for the parts that you need as well as pictures and instructions.Originally posted by motortoysrule9 View PostHey what's up everyone, I am needing new struts AND coil springs for my 93 and saw this post were did you get yours? Cuz Im having us hard time finding them, n I need them bad all around let me know thnks
Sent from my VS810PP using Tapatalk"The White Turd" 1993 Festiva 144k miles. (Winner of FOTM November 2016)
