A couple of questions about this. (Yes I attempted a search using quotation marks).
1) Has anyone else had this happen?
I have not done a real thorough investigation, just a simple look-see and it appears my proportioning valve/splitter may be leaking externally.
I've been experiencing a mystery fluid loss for a few weeks now and that seems to be the culprit.
All of the lines (except the front ones) have been changed. Calipers and wheel cylinders replaced also.
I initially thought possible master cylinder leak but removal of the vacuum hose showed no signs of dampness inside. I have not pulled the MC from the booster yet to make sure.
2) Where do I get a replacement besides a used one?
I went on the Russian sight and got the part number, ( MB03743900) Unfortunately Fourgreen doesn't show it.
IF a used one is the only option then so be it. I was simply hoping for a new replacement if, in fact the original is leaking.
