I'm perplexed. I have a coolant hose that sprung a leak. It is the hose that tees of from the metal coolant pipe that goes to the water pump and goes up into the engine. I have attached a photo of the area. The top outlet is open and the bottom has the new hose that doesn't work attached to it. I can not find out what to replace it with. If I buy similar outer and inner diameter hose it kinks when I install it because the bend the hose has to take is too great.
So how do I find out what I'm supposed to replace it with. Thanks for any help. IMG_0218.jpg
