One of 2 things either your dimmer switch is screwwed or one or both of your brights a burnt out try pulling your bulbs and replaceing them and if that doesn't work then your dimmer switch needs to be replaced I had the same problem with my 92 L.
Do the brights work when you pull back on the stalk, like you are trying to flash your lights?
If no - then you have two blown lights or a wiring problem or a switch problem
If yes - then the light switch in the steering column is probably bad.
[Edit] Wow, I just noticed that he posted that like 2 months ago :roll:
I hope you have it fixed by now.
~Jeff
2003 Mustang GT 5speed
