Bright lights dont work
  • Bright lights dont work
    The lights work on low.
    but when I put on high the lights dont work.??
    whats could this be?
    1992 Festiva
    One of 2 things either your dimmer switch is screwwed or one or both of your brights a burnt out try pulling your bulbs and replaceing them and if that doesn't work then your dimmer switch needs to be replaced I had the same problem with my 92 L.
    http://www.cardomain.com/ride/2516620/1
      Do the brights work when you pull back on the stalk, like you are trying to flash your lights?
      If no - then you have two blown lights or a wiring problem or a switch problem
      If yes - then the light switch in the steering column is probably bad.
      [Edit] Wow, I just noticed that he posted that like 2 months ago :roll:
      I hope you have it fixed by now.
      ~Jeff
      1988 Festiva LX Silver 5speed. 219,000 miles. My new daily driver.
      1988 Festiva L Plus Red 2brl 4speed. 504,477 miles and holding till I get the speed-o fixed.
      2003 Mustang GT 5speed
