For the $, you're better off swapping in a b6. Start from a better platform.
Stock Engine Swap-in. Having Issues
Time is a big issue at the moment. It's quicker for me to rebuild than search for an engine (and potentially need to modify things?) and go through smog and CARB, but do u have the link to a list of cars with what engine and trans? Also, still looking for parts list for rebuildA mechanic knows how; A technician knows why.
Wrecked. Repairs in Progress"Frankie" 1957 Chevrolet 3100, NA 2bbl 283cuin, Muncy Granny 4sp, 3.90 Open Diff @ ~95K miles
Wrecked. Repairs in Progress"Alice" 1991 Ford Festiva L, NA EFI B3, 5sp @150k miles
Reassembling"Aurora" 1991 Ford Festiva L, NA EFI B3, 5sp @240k miles
FB Festiva page: Jared Bennett
Instagram: jaredbear82
Wiki is your friend here: https://en.m.wikipedia.org/wiki/Mazda_B_engine
Since you go through smog, get the 8v sohc B6 short block from 85-90, it's a direct drop in with no mods, use your intake and exhaust manifolds and the b6 injectors. Instant upgrade and no one is the wiser but you.Trees aren't kind to me...
Ok, I will look for one, but it's first come first serve for me. Parts for rebuild vs b6A mechanic knows how; A technician knows why.
Do the b3 and b6 use the same block? Could I just bore out my b3 and use b6 internals?A mechanic knows how; A technician knows why.
Also, this "later version" of the b3; was it sold in California? Or even the US?Last edited by Sid_RallyX_82; 03-07-2017, 06:23 PM.A mechanic knows how; A technician knows why.
No, the b6 is a Siamesed block vs. the b3. The difference in bore size would force you into a custom sleeve system. Not practical.Originally posted by Sid_RallyX_82 View PostDo the b3 and b6 use the same block? Could I just bore out my b3 and use b6 internals?
Not in North America... It was a 16v version available to everyone but us.Originally posted by Sid_RallyX_82 View Post[ATTACH=CONFIG]20690[/ATTACH]
Also, this "later version" of the b3; was it sold in California? Or even the US?Trees aren't kind to me...
Damn. Well, my search goes on...A mechanic knows how; A technician knows why.
Please note that other than the bore size/style, the blocks are practically identical. All mount points are the same, and technically, the heads can interchange (b3 head on b6 block works easy, the other way round causes some valve clearance issues)Trees aren't kind to me...
So far I've found the best part about rebuilding a b3 is that it only takes one person to get it in and out of the jet washer.A mechanic knows how; A technician knows why.
I don't recall if I've asked this before, but does the B6 ex manifold fit on a b3 head?A mechanic knows how; A technician knows why.
First gen b6 will swap onto b3, 2nd gen will not unless the upper outside tabs are modified for the change in stud position.Trees aren't kind to me...
What years are first gen?A mechanic knows how; A technician knows why.
