Stock Engine Swap-in. Having Issues
  • #61
    Sorry, I should have said nominal diameter... That where a dial caliper and T gauge come into play. Just another way to verify plastigauge.
    • #62
      Originally posted by FestYboy View Post
      That's some BS. What if the dyno is feeling particularly generous that day and throws all the cars that run at the limit over? They just DQ the whole lot and say tough luck???
      How else would you do it?
      • #63
        I can check my book for Nominal thickness. Prob not gonna bother using a T gauge on the bearings. If the gap is too big, it doesn't change anything to measure it another way. If anything, if I did something wrong, the gap would most like read too small, right?
        A mechanic knows how; A technician knows why.
        Wrecked. Repairs in Progress"Frankie" 1957 Chevrolet 3100, NA 2bbl 283cuin, Muncy Granny 4sp, 3.90 Open Diff @ ~95K miles
        Wrecked. Repairs in Progress"Alice" 1991 Ford Festiva L, NA EFI B3, 5sp @150k miles
        Reassembling"Aurora" 1991 Ford Festiva L, NA EFI B3, 5sp @240k miles
        FB Festiva page: Jared Bennett
        Instagram: jaredbear82
        • #64
          Well, I say use the T gauge for the mere fact that the bearings may be over sized, creating a stacked tolerance and throwing your measurements off.
          Remember: just because it's new doesn't make it good.
          • #65
            I posted a wtb add in the For Sale section for a B6 exhaust manifold, if anyone in this section has any info
            • #66
              Is this the manifold I'm looking for?
