Is it possible to use a blank spot in the fuse box to add a new circuit? Im adding a sub and would like to put it on its own 15 amp circuit. Thanks for any help.
Fuse Box Question
It is possible, but 15A isn't much for an amp. If you do decide that route, 25A and then put a capacitor in line right before the amp. And use at least 10gaw wire. You should also replace the fuseable links with PAL fuses if you haven't already done so.Trees aren't kind to me...
Some years ago, I used this item to piggyback a fuse slot when I needed fused power for an additional circuit. These taps are available for a variety of fuse sizes: ATO, ATM, etc.Originally posted by Stinsin63 View PostMy real question is how to connect through the back of the fuze box. I don't see how to connect the wire to a spare fuze.
Thanks, that may work. I'm installing a Kicker Hideaway powered sub under the passenger seat. It has a 10 amp fuse on the back of the unit & includes a 15 amp fuse link to attach to the battery for the power.
Instead of going through the firewall to the battery I had the idea to use a blank fuse spot for the main power. Seemed simple enough until I got the fuse box out and tried to make the connection.
I added separate 30A circuits for power windows and power locks. Go ahead and add. Since I couldn't find identical open barrel fuse terminals anywhere, I recycled a couple from another fuse block. They are only a couple of bucks at a junk yard. It's easy to cut open the plastic to get at the terminals. I even got the fuses from the junk yard.Last edited by bravekozak; 02-05-2017, 06:16 PM.
Is there a thread on PAL fuse conversion?A mechanic knows how; A technician knows why.
Wrecked. Repairs in Progress"Frankie" 1957 Chevrolet 3100, NA 2bbl 283cuin, Muncy Granny 4sp, 3.90 Open Diff @ ~95K miles
Wrecked. Repairs in Progress"Alice" 1991 Ford Festiva L, NA EFI B3, 5sp @150k miles
Reassembling"Aurora" 1991 Ford Festiva L, NA EFI B3, 5sp @240k miles
FB Festiva page: Jared Bennett
Instagram: jaredbear82
It took me less than 30 seconds to find thread 56588 using the search engine. Try it sometime. It's located at the top right of every screen. I get all of my fuses and light bulbs at the junk yard, including PAL fuses.Last edited by bravekozak; 02-06-2017, 06:47 AM.
